someone please
Old Feb 25, 2008 | 07:58 PM
electricheart4's Avatar
Default someone please
can anyone give me any info on how to get oil and water out of my furl injection? i was told that my oil was having nowhere to go so it was pushing itself anywhere it could which resulted in it ending up in my fuel injection. someone told me this when i had them start working on the head gasket and he found lots of oil and water in it. someone please help !
Old Feb 26, 2008 | 06:18 AM
02StanGT's Avatar
Default RE: someone please
They saw this in your fuel system? I highly doubt they found oil in there, unless you are dumping it in your gas tank... Water I could believe as it can accumulate in the tank over time. Get new mechanics or find out exactly what they said.
Old Feb 27, 2008 | 04:08 AM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
Rubbing alcohol in the tank will evaporate the water, this is an older trick and might mess with the sensors so be carefull. I agree with stang, cant see oil and water in the fuel injectors, unless it was put in your tank that way by someone you made mad.
Where exactly was the oil water mixture found? near the intake manifold (under it)? is there water on the dipstick?
