Rear Main Seal for my 355cid.
I had th mains aline bored on this 355sb.Now there seems to be some question on what rear main seal to use. Hoping to use the best one I can . But When I ck. on line ( Summit Racing) their on line catalog.Were itlists check for application ,their FEL-PRO-FPP2912 Proformance Sealindicates no aline bore mains. I know when you aline bore the mains that you open upthe stock dimensions. So what rear seal do I use
ROG(really old guy)
ROG(really old guy)
RE: Rear Main Seal for my 355cid.
rat 454 it's a 2 piece block.But I should have said aline honed ,not bored. fact the mach. shop said that there wasn't thatmuch done .that it only needed a touch up. took longer settting up the block then honing the mains . one pass on the mains.
