Rear Main Seal fix
Old Aug 28, 2007 | 02:30 AM
94Red's Avatar
Default Rear Main Seal fix
I got a little oil leaking through the drip hole in my Tranny Bell Housing, and i had it up on the lift at my friends shop, he said it might be my Rear main seal??, anyone know if this is fixable by myself? anyone do it already? and if so/not, any websites with pics or anything to help me out?
Old Aug 28, 2007 | 09:53 AM
daltons 1980's Avatar
Default RE: Rear Main Seal fix
rear main seals suck....as far as i kno...from what i understand you gotta undo the motormounts jack up the motor and drop the and drop the oil pan to get them out...you could probably do it yourself but its a job
Old Aug 28, 2007 | 11:59 PM
94Red's Avatar
Hmm interesting any1 elsE????
Old Aug 29, 2007 | 12:19 AM
Chappie99's Avatar
If its just small drips, let it be. If it is bigger drips, that eventually will become a puddle, maybe you should take car of it. Rear mains seals are not for people that are inexperienced. Its a labor intensive job that requires time. Keep an eye on it, if you start to smell burning oil cause its getting on your exhaust, do something about it. If its not leaving puddles of oil where you park, a drip here and there, dont worry. Just frequently check your oil. The motor has to be jacked up, the oil pan has to come out. blah bla blah..
Old Aug 29, 2007 | 12:54 AM
94Red's Avatar
Ahhh i c i c , well i think its my rear main, now i will keep an eye on my oil and what not for sure, i dont smell any burning oil which is good lol, but i have a feeling its my valve covers.
Old Aug 29, 2007 | 10:02 AM
The LT1 engine is known for developing oil leaks at the top rear of the block where it meets the intake manifold. The oiloozes down the back of the block and into the bell housing and drips out of the hole in the cover. Before you go about changing the rear seal and accomplish nothing, run your fingers where the rear of the intake manifold and engine block meet & check for oil.
Chevy101
Jul 7, 2012 07:02 PM
bd92rs
Dec 16, 2010 11:03 PM
94ttop
Aug 13, 2009 08:23 PM
sp9o3
Nov 29, 2007 07:27 PM
eas69
Sep 19, 2007 11:32 AM
