quuestion about my engine?
Old Oct 19, 2007 | 12:10 PM
Thorshammer0's Avatar
Default quuestion about my engine?
I have an original 79 z28 350 v8 in my car. it has been bored 30 over, 11 to 1 TRW pistons, original heads cut for 375 valves, 30/30 solid lift cam, a 830 holley carb, a 350 turbo tranny with 2500 stall and a 3:73 LSD rear end.
Can anyone guesstimate what my horsepower range is?
Also, does my displacement change with it being bored? if so, whats the result?
Thanks a lot.
Old Oct 19, 2007 | 03:40 PM
Default RE: quuestion about my engine?
Hard to tell, it depends on how well the engine is tuned. Take a few runs at a drag strip, and the top speed is a pretty accurate measure of how much power it has.
Old Oct 19, 2007 | 05:49 PM
GRIFF's Avatar
355.5 CI Pete is correct not enough data to tell, heads are a big deciding factor smog heads usally dont flow all that well (except the 993 casting from what ive seen) and what do you mean by cut for the 375 valves?
onefastls1
Jan 2, 2013 01:45 PM
Rynos68
Oct 9, 2011 06:27 PM
martynlutherking
May 25, 2010 11:12 PM
Chevykicksbut
Oct 28, 2009 07:14 AM
drabina
Jul 25, 2008 08:56 PM
