PLEASE HELP!!!
Old 12-01-2007, 09:59 PM
luvmysccamaro's Avatar
Default RE: PLEASE HELP!!!
well first i need to save some money and ill do the rebuild. its not a four speed because there is the slot for 5th and 6th gear, they just dont engage. and the top speed in 4th is 110 and dont four speed got faster thatn that?
Old 12-02-2007, 10:29 AM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
Since you posted the link to a vendor of tranny's, and it was for about 2500.00 are you willing to spend tha much? If so you can look into keisler at: http://www.keislerauto.com/
Old 12-02-2007, 11:23 PM
a good friend/mechanic told me the problem isprobobly the shifter and it makes sence becauseit is sometimes difficult to put in in reverse. could this be the problem?
Old 12-06-2007, 12:37 AM
so does any one know if it could be the shifter?
Old 12-06-2007, 04:30 PM
cbr600rx7's Avatar
It could be. Take it too a shop and have it looked at. Its easy to do your self but if you do make sure you know what your doing. I would lay off the evo's untill you take care of this isue if it is the trany you could be hurting her ever more.
Old 12-06-2007, 09:20 PM
camaro maniac's Avatar
thats actually very possible, not being able to shift into some gears or having a hard time shifting into them, or them jumping out of gear, it could be caused by a couple of things, it could either be misadjusted linkages for the shifter, the synchros in the tranny, worn gears, and so on, but i would deffinetly bring it somewhere to get looked at if you don't want to drop the tranny for nothing,
Old 12-17-2007, 01:45 AM
all right, im getting it fixed wednesday. the guy who sold the car to me said the roll pin that connects the gears to the shaft broke and i hope thats the problem because then it would be a very cheap fix
