p0300, p0404, p0405, p01404
Old Jun 15, 2010 | 11:21 AM
kbfour's Avatar
Default p0300, p0404, p0405, p01404
99 3.8 139,000. new engine at 118,000 and new egr. The car will barely move under load, idles fine. getting some rattling from underneath by the catyletic converter. I am thinking bad converter causing all other codes. what do you think?
Old Jun 15, 2010 | 02:17 PM
The main problem seems to be the EGR as the PCM does not see the EGR pintle moving as commanded. The misfire code is most likely related to the EGR. HOWEVER, if the cat , as you mentioned, is messed up and choking the engine it will cause all of the problems. The engine will misfire, and the EGR may be moving as commanded but the excessive back pressure will force exaust gas back through the EGR and into the intake causing the EGR codes to be set, not to mention that excessive back pressure will cause severe power loss. You can have the cat tested for excessive back pressure to make sure. If you do change the cat, it would be a good idea to clean out all the carbon from the EGR and associated passages, and put in new set of plugs.
Old Jun 15, 2010 | 03:02 PM
But...but...but...I thought backpressure was good?
Bang on the cat converter and listen for a chunks of rocks sound. Could be broken up inside, but it sounds like you need to give the cat a close look from the inside regardless.
Old Jun 15, 2010 | 04:00 PM
Now we know what back pressure is good for. Back in the very old high school days, we used to stuff a raw potato into a teacher's car exhaust pipe, and laugh our ***** off as he tried to drive out of the parking lot.
Old Jun 15, 2010 | 04:06 PM
Yeah, my dad told me about that trick many years ago.
I'm not implying anything...just saying. lol
arodrig
Dec 2, 2011 01:59 PM
Deeman3009
Sep 21, 2011 01:58 PM
Jonny Dubyah
Oct 2, 2009 05:34 PM
30thAnnivCamaro
Feb 21, 2009 11:06 AM
lt1z28
Aug 16, 2007 07:04 PM
