new ls9
Old Dec 20, 2007 | 05:44 PM
511bbc's Avatar
Default new ls9
Hey everyone, i was wondering what the new ls9 is bore/stroke and what everyone thinks about a supercharged 600+ hp vette, i cant wait for the new camaro and would love to see the ls7 in it. thanks
Old Dec 25, 2007 | 12:55 PM
511bbc's Avatar
Default RE: new ls9
i found the info, thanks for looking........2009 LS9
620+ HP/595+ FT-LBS
6.2L, 319-T5 aluminum block
103.25mm (4.06-inch) bore x 92mm (3.62-inch) stroke
forged steel crank
titanium rods
9.1:1 forged aluminum pistons with oil-spray cooling
356-T6 aluminum heads
titanium 55mm (2.16-inch) intake and hollow-stem, sodium-filled 40.4mm (1.59-inch) exhaust valves
Offset-rocker valvetrain layout
2.3L supercharger pushing 10.5psi boost
100HP/Liter target
Old Dec 25, 2007 | 01:13 PM
02StanGT's Avatar
Default RE: new ls9
So instead of looking yourself, you were wanting us to find it?
Old Dec 28, 2007 | 03:53 PM
511bbc's Avatar
Default RE: new ls9
if you notice the date of my first post, you will notice it was on the 20th....gm did not give out the info until the 23rd.. and i did look and a couple days later i looked again and gee guess what i found. so you figure it out..........
Old Dec 28, 2007 | 04:56 PM
LT1RUNNER's Avatar
Default RE: new ls9
Those are some wicked numbers!!
Old Dec 28, 2007 | 07:50 PM
cbr600rx7's Avatar
Default RE: new ls9
Good info thanks for the input.
Old Dec 28, 2007 | 08:51 PM
luvmysccamaro's Avatar
Default RE: new ls9
so will the ls9 be a supercharged version of the ls3?
Old Dec 31, 2007 | 03:48 PM
purpl96's Avatar
Default RE: new ls9
From what I gather it seems as though it is just a supercharged ls3. But the ls3 has what 430hp? + the 100hp added by the sc thats only 530hp. Where does the other 90hp come from?
Old Feb 4, 2008 | 08:46 PM
buckfever's Avatar
Default RE: new ls9
better heads, cam, tuning, maybe?
Old Feb 4, 2008 | 09:08 PM
95slvrZ28's Avatar
Default RE: new ls9
ORIGINAL: purpl96
Why are we limiting the S/C to a 100 HP limit? It's more than capable of producing more, especially with better heads and a cam to match. Not to mention it probably has titanium valvues etc. so they can push the rpm's higher as well.
