lt1 cam problems
Old Jun 11, 2007 | 11:05 PM
97ultrazb's Avatar
Default lt1 cam problems
i got and new hott cam 1.6 rollers valvesping and car wont stay running and no shift out of first and a little grinding in engine be fore i got it towed 97 5.7.auto
Old Jun 12, 2007 | 10:09 AM
94Z28SHAKER's Avatar
Default RE: lt1 cam problems
did you measure the pushrod length? new lifters? did you check that the valve springswere correctly seated?
did you take the rocker covers off yet to see if something was messed up in there?
Old Jun 12, 2007 | 12:17 PM
Stop asking all those pertinent questions. Just give an instant fix. LMAO
Old Jun 12, 2007 | 07:29 PM
LOL, duct tape should work!
Old Jun 14, 2007 | 01:18 AM
95slvrZ28's Avatar
Well, hopefully he didn't skrew it totally up and drop a valve into the cylinder and then started it! [:@]
Old Jun 14, 2007 | 09:03 AM
derrickdiggler's Avatar
Buddy of mine put a hot cam into his 96' SS, had same problem with it running, ended up having to get a new computer to work with that cam. Though the grinding isn't a good sign....good luck.
mp734
Nov 6, 2013 11:54 AM
nmallory56
Jul 21, 2009 03:34 PM
IZZY1967RS
Jun 19, 2008 10:29 PM
jdubs1813
Nov 12, 2007 04:16 PM
Nov 11, 2007 11:56 AM
