LS1 Heads, Cam, and CPU
Old Aug 9, 2009 | 06:44 PM
01Z28smith's Avatar
Default LS1 Heads, Cam, and CPU
What are a good set of heads and a cam. also i heard the ls6 roller rockers are a good addition to any head. Just wondering if thats true cause my dad has a set laying around in his shop. With most new cams and heads for the ls1 i know u need to have the CPU remapped. does a Chevy dealer do this or is it better to go to a specialty tuning shop. Thanks for your time.
Old Aug 9, 2009 | 06:50 PM
Saint_Ali's Avatar
what are your plans for the car ?
Old Aug 9, 2009 | 08:28 PM
Lee Willis's Avatar
AFR heads are generally the best I've seen. I had a set of special order heads fro a placve called Justin Engineering or someting on my 'vette that were a bit better for Sc'd applications, but that company, whatever its name was, has gone bust. roller rockers make a lot of sense with big cams. Go with name brands though. I stick with Crower myself: we had some problems with a no-name set that we had and put on the Camaro -- I want to say it was something like Falcom, but frankly I don';t really remember -- they fit well and worked at low RPM but at the track and really high oil temps their bearings seized up, luckily without any damange to the lower end.
fbodyhemi69
LS Series Tech
Dec 7, 2009 05:16 PM
SixShooterCamaro
Oct 30, 2009 08:58 PM
Red Demon
Oct 25, 2007 02:29 PM
1983_JAL
Mar 23, 2007 11:57 PM
