Low compression
Old Oct 13, 2006 | 08:17 PM
dmacqrazi's Avatar
Default Low compression
I've been told that i have low compression in cylinder 1... how bad is it and what are the possible damaging effects?
Old Oct 13, 2006 | 11:00 PM
SickSickSick's Avatar
Default RE: Low compression
it depends on why the compression is low. bad rings ... leaky head gasket ... unseated valves ... wore out cylinders. you can remove the plug and pour a little oil down in the cylinder. then check the compression again. if it helps that will rule out a leaky head gasket and unseated valves. which would leave you with bad rings or wore out cylinders which means the bottom end needs rebuilding. if the oil doesn't help that usually means bad gasket or valves which then your top end needs attention. Sick
Old Oct 13, 2006 | 11:35 PM
shnormo's Avatar
Worst comes to worst, your motor siezes up. If the piston rings or cylinder walls are worn out there is a lot of blow by and the air fuel mixture leaks into your crankcase diluting your oil and eventually breaking it down and losing it's lubrication. If it's a bad head gasket, coolant can leak into the cylinder causing bent valves or hydrolock. Usually if it is a bad seating valve, there is some somke in the exhaust.
Old Oct 14, 2006 | 09:41 PM
dmacqrazi's Avatar
thank u sir.
dmacqrazi's Avatar
thank u sir.
NorthernCrew454
Oct 17, 2011 09:30 AM
BasicConcepts
Sep 11, 2010 03:14 PM
BasicConcepts
May 7, 2010 06:43 PM
z-28foxx
Feb 10, 2010 11:33 PM
Bennyt900
Jun 1, 2007 10:22 AM
