I need some feed back
Old Apr 30, 2011 | 05:40 AM
mikey0oo's Avatar
Default I need some feed back
I have a 1967 327 chevy, 202 heads,hyd roller cam, dome pistons 13.1 compression, air 4 intake. what would be a ideal carb ?,i don't want over cab.
Old May 4, 2011 | 12:00 AM
Osmiumfoot's Avatar
That's a lot of compression! Do you drive it on the street? If so, I would think the old standard 750 double pumper would be fine. Quickfuel makes some nice ones.
Old May 11, 2011 | 10:39 AM
IMO that is a tiny bit too much compression for street use, unless you are burning alcohol or racing gasoline, especially with an hydraulic cam. What do you plan to do with this engine?
Old May 14, 2011 | 06:25 PM
mikey0oo's Avatar
Thanks
Old May 20, 2011 | 11:09 AM
need4speed069's Avatar
Are u planning to run it on E-85 with that compression
1998camarossclone
May 11, 2013 11:05 AM
dynarider33
Oct 29, 2010 10:20 AM
RMG32
Jun 26, 2008 12:03 PM
hot_rod_rodney1952
Dec 11, 2007 03:57 PM
