Holley carb vacuum question
Old Feb 26, 2009 | 05:04 PM
kyphur's Avatar
Default Holley carb vacuum question
Hey, I have a 3310 750cfm vacuum secondary carb that runs pretty darn tight. I have the vacuum advance hooked up to the metering block rather than baseplate port. Is this correct? When the car is running it sounds like it's sucking large amounts of air and I can pinch the hose to the vacuum advance and it goes quiet and when I release it comes back. Could the diaphragm in the vacuum advance have blown and creating a huge vacuum leak or is this the way it's supposed to sound from this port?
Old Mar 29, 2009 | 07:01 PM
PAzYearazzUP's Avatar
Originally Posted by kyphur
Hey, I have a 3310 750cfm vacuum secondary carb that runs pretty darn tight. Could the diaphragm in the vacuum advance have blown and creating a huge vacuum leak or is this the way it's supposed to sound from this port?
Let me ask you a question. How fast will the metering block return to atmospheric pressure? How fast will the baseplate port fill back to 14.7 psi?
If say both filled back to atmosphere equally, would the vacuum advance run as stout as you say how tight running that Chevy runs? You did mean, "Tight" as tight as a drum? As fit as a fiddle. As in you have pinks, we race for pinks you are going to lose this car is that 'Tight?'
Old Mar 29, 2009 | 07:03 PM
kyphur's Avatar
Tight = strong
It was the vacuum advance diaphragm that was blown.
ssnowden1982
Aug 31, 2011 02:30 PM
sewerrat
Jul 13, 2009 04:57 PM
jbe123
May 12, 2007 09:37 PM
jbe123
May 7, 2007 09:28 PM
1969 Camaro
Jun 3, 2006 04:03 AM
