HEAD FLOW CHARTS
Old Nov 26, 2006 | 03:15 PM
GRIFF's Avatar
Default HEAD FLOW CHARTS
http://racingdownloads.com/racing_software-26.html Kind of interesting especially the early small block heads. DAZ28 originally posted this on the Sunset Dragstrip web site http://www.freepowerboards.com/sunse...rip/portal.php .
Old Nov 28, 2006 | 10:20 PM
uncle bill's Avatar
Default RE: HEAD FLOW CHARTS
Thanks Griff, it's loaded with good info nd pretty accurate numbers too.
Old Nov 28, 2006 | 11:59 PM
GRIFF's Avatar
It is kind of interesting especially some the early stock chevy smallblock heads seem to be capable of the 400 hp mark I am looking for in the budget 350. I have a set of early 400 heads I think they are 493 castings whats odd about them is I think they have 1.94 intake and 1.6 exhaust?? I am going to get the dremmel out and clean up the ports replace the guides, valves and springs get a set of roller tip rockers. While I have the dremmel, is there something mild I can do as far as porting I have heard removing a little off the top of the port can help any suggestions???
Old Nov 29, 2006 | 11:03 PM
da Z28's Avatar
You can trim down some casting around the valve guide, that is usually some restriction. The first inch or so in the bowl area is where ya get the most gains from what Iv'e been told. That includes the valves.
Old Nov 29, 2006 | 11:36 PM
GRIFF's Avatar
Ive read some on the subject boy it can get complicated in a hurry I think you would really need a flow bench to figure out if you are making a difference. I think I can put together a bench once I figure out the flow guage stuff might need to have a metal plate made to bolt on the bottom of the head, I can get a decent sized blower and motor and whatever pvc pipe and fittings from work and we use magnehelic and flow guages. Anyone know anybody who has tried to build a simple bench?
VALHAR
Nov 22, 2014 12:28 AM
NorthernCrew454
Mar 31, 2011 05:51 AM
z28pete
Apr 7, 2010 10:34 PM
bowtieguy
Feb 15, 2008 11:42 PM
deswitzki
Aug 9, 2005 11:45 PM
