Harmonic balancer question
Old May 19, 2008 | 08:40 PM
kyphur's Avatar
Default Harmonic balancer question
I was installing my old harmonic balancer earlier this evening and while torquing it on I was noticing that the rubber seal on the back of it (the seperation ring) was up against the timing cover. I thought there was supposed to be clearance between the balancer and the timing cover? I know the key is pretty much straight through and if I remember correctly the key on Ford motors has a stopper on it that keeps the balancer from going too far back. I moved over to a comp cams double roller timing chain, could the lower sprocket be thinner than the old one I had and letting it go back further?
Any thoughts on this would be appreciated.
1976camaro
70-81 V8 Tech
Dec 14, 2010 12:28 AM
Gas Hed
Nov 24, 2009 05:09 PM
jarrod1875
LS Series Tech
Oct 29, 2009 12:45 PM
nazariol
Jan 12, 2009 12:40 AM
chrshadil
Aug 12, 2007 09:03 PM
