GTP Supercharger for 95 3.4L V6
I can't remember where I read this but someone said that with a little modification, you can put the stock GTP supercharger on a 3.4L 60 degree V6...Is this true? I can buy this supercharger for $50 from a wrecked GTP and put it on mine but I was wanting to know if its possible. Any info would help a lot. Thanks
GTP's in 95 are not supercharged, as for putting a newer one on it, i doubt that the 3.8 has the same pulley system/ belt length, and the electronics/cpu would have to be modified along with fuel pump/injectors.
