Good sized Cam?
Old Oct 11, 2006 | 02:45 AM
69camaro1's Avatar
Default Good sized Cam?
Im rebuilding a 350 with 2.02 alunimum heads, headers, 10:25:1 compression cast pistons, and a 750 cfm holley. I need to know if a cam with a 268 degrees duration and 280 degrees of lift is just right for this engine combonition.
Old Oct 11, 2006 | 12:20 PM
shnormo's Avatar
Default RE: Good sized Cam?
Are you looking for top end power or low end torque? It will give you a mild performance increase.
Old Oct 11, 2006 | 02:22 PM
69camaro1's Avatar
Well the car its going in will be a daily driver and will have 3.73 rear gears so im guessing low end tourqe. Will this cam have a nice lope?
thx
Old Oct 11, 2006 | 02:35 PM
shnormo's Avatar
It will have some lope, but the more lope you have the less lowe end power you're going to make. You can get away with a slightly larger cam since you have a higher rear end ratio. Something that would also help are new roller rockers I don't know your budget, but just reduce friction.
Old Oct 11, 2006 | 02:43 PM
Doc's Avatar
Doc
Call comp cams, and tell them what you want. they will put together a whole package for you that will do what you want.
Doc
Old Oct 11, 2006 | 05:53 PM
69camaro1's Avatar
Thanks for all of the info.
Old Oct 12, 2006 | 03:10 PM
69camaro1's Avatar
I will call comp cams and set up a package deal.
thx
TylerTman
Apr 9, 2012 01:01 PM
libertyforall1776
Oct 17, 2010 05:58 PM
luciora
Apr 7, 2010 11:28 AM
BeachBrad
Aug 10, 2007 11:54 AM
