Electric fuel pump
Old Aug 19, 2009 | 08:39 PM
redeyerace's Avatar
Default Electric fuel pump
I recently purchased an external electric fuel pump for my 68. Has any one installed one on their car? Where is the best place to mount them? Any help would be great.
Thanks
Old Aug 19, 2009 | 10:08 PM
As close to the tank as possible, since it's better for the pump to push the gas than pull it. It would also be a good idea to install a fuel pressure regulator under the hood somewhere before the carb, with a return line to the tank. Not only will a regulator prevent a carb. overflow if the pump is putting out a little too much, but the return will help to make your pump live longer.
Just curious, why the electric pump anyway?
Old Aug 21, 2009 | 12:06 AM
redeyerace's Avatar
Thanks for the info. The electric pump was recomended to help with starting problems I was having due to vapor lock.
silverandblack69
Jul 30, 2013 12:55 PM
Texas70z28
Jan 20, 2011 10:42 AM
nj85z28
Jun 11, 2009 11:19 PM
Gregster325
May 29, 2007 09:00 AM
68greenss
Jul 12, 2006 10:14 AM
