Electric Cutouts
Old Oct 25, 2007 | 03:49 AM
luvmysccamaro's Avatar
Default Electric Cutouts
ok, i am going to get one. my camaro has dual exhaust so do i get two: one for each pipe or just one? and if i get one, which side do i put it on?
Old Oct 25, 2007 | 04:55 PM
JRs72RS's Avatar
February 2009 ROTM
Default RE: Electric Cutouts
If you have true dual exhaust or anytime you have headers, you should install two cutouts.
Old Oct 25, 2007 | 05:52 PM
SpecterGT260's Avatar
Ninja Administrator
not necessarily, you could install 1 cutout after the junction of a Ypipe with headers. wouldnt be a good as 2, but still much better than running through a catback. I however will do 2 when i get the money
Old Oct 26, 2007 | 01:47 AM
95slvrZ28's Avatar
Although a good header/Y-pipe and cat back can support 500+ HP, so I'm not quite sure why we would want to do this unless we just want to make noise.
Old Oct 26, 2007 | 08:37 AM
69dmz's Avatar
I have 2 on my exhaust about a foot and half after the headers on my 69 camaro. Quick time performance is where I ordered mine.They come wired to 1 toggle switch and can be opened to a 1/4,1/2, and 100%. I purchased dynamax cutouts with a rotating flange so it tucks up nice. I was told my car purrs like a kitten when closed and roars like a lion when opened. I think I read on the website that it adds some horsepower. The video on the site will show you how they work.
Old Oct 26, 2007 | 09:39 AM
Ninja Administrator
ORIGINAL: 95slvrZ28
the exhaust is still a restrictor. any component on the stock car is capable of supporting alot of power, but if you improve it you will make more. sometimes only a little, some times alot. a 500hp car through a full exhaust will pick up some extra power by cutting out the exhaust.
Globert 67 Pro Street
May 31, 2010 08:49 PM
Antwan
LS Series Tech
12
May 10, 2010 02:32 AM
ranf023
May 15, 2008 04:25 PM
luvmysccamaro
Nov 21, 2007 08:43 AM
Mortx15
Aug 16, 2006 06:21 AM
