compression
Old Jul 4, 2006 | 02:31 AM
bowtieguy's Avatar
July 2009 ROTM
Default compression
my 454 is pulling 180 psi of compression.the engine builder that sold me the pistons said they were about 9.2-1.this seems a little high for just 9.2-1 pistons.the pistons have a .210 dome and the heads are a 781 casting.maybe some of you big block junkies can figure this out for me.the engine builder said this head was one of the better big block castings they made.this s.o.b. pulls hard and has that roar that only a big block has and i believe ,that i'm up around 10-1 to 11-1 compression.tell me what you know
Old Jul 4, 2006 | 06:19 PM
Default RE: compression
It is pretty difficult to determine the compression ratio by taking a compression reading, a lot depends on the duration and overlap of the camshaft. The milder the cam the higher the compression reading will be & vice versa. The only sure way to tell is to physically measure he volume of the cylinder and the combustion chamber. If it runs good, don't worry about it.
NorthernCrew454
Oct 17, 2011 09:30 AM
BasicConcepts
Sep 11, 2010 03:14 PM
BasicConcepts
May 7, 2010 06:43 PM
z-28foxx
Feb 10, 2010 11:33 PM
Bennyt900
Jun 1, 2007 10:22 AM
