compression
Old Mar 28, 2007 | 03:30 AM
z28child's Avatar
Default compression
im debating buying a set of new (higher compression)heads for my 350 2bolt main
i dont know the make of them they were bought brand new for $1000
the guy just wants to get rid of them hes willing to sell for $600 obo
anyways i was wondering how high compression i can run before my engine starts to fall apart on me and if i raise compression a significant amount how much more hp/torque is this goin to give me
am i goin to have to swap out my camshaft and intake manifold as well to see some power or will the heads be sufficient
i dont need 450horse i just want a little more power to mess around with
(78 z28 350 2 bolt main 4 speed manual trans)
Old Mar 28, 2007 | 07:22 PM
machineman's Avatar
Default RE: compression
Are these heads cast iron or are they aluminum? For pump gas, I prefer to stay in the 9.5:1 range with cast iron and you can go up to a full point more with aluminum.
On AVERAGE, one full point of compression is worth about 30-40 HP in a V8 engine. There are other factors to consider but that is a rough estimate.
A larger cam will cut some of the cylinder pressure and make an engine with high compression a little more tolerable to low octane fuel.
NorthernCrew454
Oct 17, 2011 09:30 AM
BasicConcepts
Sep 11, 2010 03:14 PM
BasicConcepts
May 7, 2010 06:43 PM
z-28foxx
Feb 10, 2010 11:33 PM
Bennyt900
Jun 1, 2007 10:22 AM
