Check Engine Light?
RE: Check Engine Light?
that could be anything. i work at a chevy dealership and i see these all the time. whatever set the code sounds like a one time system fail. being that there is no check engine light on everything is probably alright. the system will reset the light after so many ignition cycles. if you want you can take your car to a dealer and scan it for you because it should be saved in the cars history.
