casting numbers help
Old Jan 8, 2009 | 09:58 PM
Camaro_Boi69's Avatar
Default casting numbers help
well im supose to be buying some 305h/o heads this sunday and i was wondering if anyone knew how to find out whatthe casting numbers are?so i dont screw myself over..
like a link to a website er anything would be helpfull.
this would be greatly aprecieated.
Old Jan 8, 2009 | 10:41 PM
Default RE: casting numbers help
Head Casting Number Guide
Scroll down to the lower half of the page.
#14014416, 14022601 (1980-85) perimeter valve cover bolts.
#14102187 (1987-91) center bolt valve covers.
All are 58cc combustion chamber, so keep in mind you'll be bumping up your compression ratio.
Old Jan 8, 2009 | 11:01 PM
thanks alot your a big help.
and im really diggin that 1st gen. its done up reall nice! =)
been using google to find sumthing on it but not even close.
Old Jan 8, 2009 | 11:09 PM
GRIFF's Avatar
Are the 187 ones the swirl port heads?
Old Jan 8, 2009 | 11:41 PM
ORIGINAL: GRIFF
Whoops, yes they are. Stick with the first two. The 187 heads won't breathe well in the higher rpm range.
Old Jan 9, 2009 | 07:58 AM
blackz87's Avatar
For others, the web site is mortec.com for engine & head identification.
Old Jan 9, 2009 | 10:54 PM
ok thanks for that quick call on the 187 heads.
i dont want them i would basicly end up with what i got then except small cc.
but thanks for the help everyone it is greatly apreceated
Old Jan 12, 2009 | 10:28 PM
Thanks for the help everyone got the heads i wanted and got them for a steel for 50for the pair and with valves
but there in the shop getting magnufluxed grinded n port n polishedwith new valves and seats an guides with .550 lift valve. the whole rebuild is costing me a lil under 300 is that a good deal?
palmers68
Apr 12, 2013 07:10 PM
MN79Camaro
70-81 V8 Tech
Feb 18, 2012 09:43 PM
mikes68
Jan 19, 2012 09:40 PM
pyrofire127
Jan 27, 2008 11:03 AM
sweetquads
Aug 8, 2007 08:40 PM
