Car stalls when I accelerate?
1986 Z28 with 350 small block, Holley 4 barrel carb.
I get some back fire as well. Seem's like the car bogs down when I press the gas to go. Stalls out and sputters often when you press the accelerator.
The Carb is pretty new, less then a year old and I don't drive the car often.
Funny thing is when I had the stock Carb I never had problems, it was only when I "Upgraded"
Any help or idea's would be appreciated.
Thanks.
Thanks.
I gave up working on carburetors back in 1972, but you could start with the accelerator pump. Try different stroke settings & see if things get better or worse. May also want to check ignition timing. As the old sayng states, "don't fix it if it aint broke". lol
1986, accelerate, accelerated, accelerating, bogs, car, carbureted, carburetor, chevy, engine, onan, stall, stalling, stalls, z28
