Bought a 69, What motor is it?
Old Jul 15, 2006 | 01:21 AM
CamaroCrazy1969's Avatar
Default Bought a 69, What motor is it?
I bought a 1969 GM car (i got out of hondas) to drag race from a young man for 24K. He said there was a lot of goodies and there is. it is back halfed with a 10 point cage. nice purple paint with his old sponsers stickers on it, nice intirior with nice tin work... to much to say. what i realy like is the motor. he set it up himself with front and midplates, aluminum heads, victor intake. 4 barel carb. braided line, home made headers. it realy suprised me when he started it up. i dont remember if said it was a small or a big block. i'm kinda new to domestics but not that new. he also said it produces 580hp at the flywheel, this is a naturally asperated motor. what kind of motor can make that power? i can discribe to you what it looks like, i'll have some pics soon... the valve covers have 4 bolts each. the exhaust 0-00-0 has that pattern the intake has -00-00- patern, distributor in the back 3 freeze plugs on the side, water pump looks really accessable, a friend said it looks like a big block because it is really big, but who knows. thanks for the help
Old Jul 15, 2006 | 02:52 AM
94Z28SHAKER's Avatar
Default RE: Bought a 69, What motor is it?
sounds nice man, got a nice car there!
Old Jul 15, 2006 | 09:34 AM
SickSickSick's Avatar
you have just described almost every V-8 engine GM has ever made LOL. if the rear of the engine is fairly clean and easy to get to, get a flash light and look around the rear of the block close to where the tranny bolts up. the cid will be stamped there. sick
Old Jul 15, 2006 | 03:15 PM
I looked in the back and could not find any stamping. how do you put pics on with your reply. i have some engine shots i can post. thanks a bunch
Old Jul 30, 2006 | 07:23 PM
firebird69racer's Avatar
four bolts on the valve cover and the exhaust pattern you showed its a small block, big blocks have an exhaust patteren 0-0-0-0, also on the big blocks the water pump will have a hose on top going to the intake, and the valve covers are about 6-7 inches wide.
3 freeze plugs on the side will be a factory 400 small block or an aftermarket block. with the work that has been done I would bet it was an aftermarket big inch small block. The guy you bought it from didnt know what the CID of the motor was?
Old Jul 30, 2006 | 07:29 PM
ORIGINAL: SickSickSick
I have never seen the CID stamped anywhere on the block, just casting numbers on the rear and date and vin codes on the pad by the water pump, which would tell you what the enging came out of and CID if it was factory installed into a car, dealer installed replacment motors dont
Old Jul 30, 2006 | 07:56 PM
most of the time you'll never see it unless you have thoroughly cleaned a block for painting. sick
Old Aug 1, 2006 | 02:13 AM
I have built a many small blocks 1955 265's through mid 80's 350's and cleaned every one before they get built, even sand blasted a few of mine clean.
still dont remember seeing it, as I have checked the blocks completely to check the casting dates and for any sign's of cracks
Old Aug 1, 2006 | 11:09 AM
digiti's Avatar
Pics would help!
Old Aug 17, 2006 | 02:55 AM
decipha's Avatar
yes yes pics pics plz
