Best piston to compression
Old Nov 4, 2006 | 11:12 AM
69camaro1's Avatar
Default Best piston to compression
I want to run 70cc heads with 2.02 intake valves. I'm running a 350 and I want to know what piston would achieve 10.0.1 to 10.25.1 compression?
Old Nov 4, 2006 | 11:26 AM
uncle bill's Avatar
Default RE: Pistons
It would have to have a small dome to it, most likely would be the 70 LT1 pistons that were 11-1 with a 64 cc head. I'm sure that TRW and Speed Pro still have them available.
Old Nov 16, 2006 | 07:35 PM
69camaro1's Avatar
Default RE: Best piston to compression
Thanks for the info. I've decided to stick with 64cc heads because it is much easier to accomplish the compression ratio I want and I noticed that it isn't that commen to find a wide varity of pistons for 70 or 72cc heads.
DarlingReject
May 19, 2010 10:00 PM
Eric89RS
Sep 22, 2007 04:01 PM
jdubs1813
Apr 30, 2007 04:03 AM
vampyrico
Apr 25, 2007 03:16 AM
