Balancing 350
Old Jun 25, 2007 | 10:30 PM
Scarface69Camaro's Avatar
Default Balancing 350
I wanted to know...
Do i need a flexplate or flywheel before balancing my rotating assembly?
Also what would happen if i didnt get the assembly balanced? How would it run? JW...
Old Jun 26, 2007 | 04:48 AM
STICKIT's Avatar
Default RE: Balancing 350
HI SCAREFACE69CAMARO YES YOU WILL REQUIRE A FLYWHEEL OR FLEXPLATE AND A BALANCER FOR THE BALANCING
PROCESS YOUR MOTOR WILL BE FINE WITHOUT BALANCING AS ALL THE PIECES ARE CLOSE FROM THE FACTORY
YOU BALANCE A MOTOR TO GET THE PARTS TO WORK IN HARMONEY WHAT DOES HAPPEN THAT ALL THE PARTS ARE EVEN
AND THIS HELPS ON BEARING LIFE AS ALL ROTATING PRESSURES ARE EVEN I WILL SAY THAT BALANCING A MOTOR IS ONE
OF BEST INVESTMENTS YOU CAN MAKE IN BUILDING AENGINE
HOPE THIS IS SOME HELP TO YOU HAPPY MOTORING
STICKIT
Old Jun 26, 2007 | 06:47 PM
thnaks for all the help
Old Jun 26, 2007 | 10:30 PM
GRIFF's Avatar
For a normal balance job on a internally balanced 350 you do not need the damper or flex plate to have it done. Externally balanced engines like the 400 require the damper and plate unless they have been changed to a internally balanced crank.
Old Jun 28, 2007 | 03:02 PM
bluovlh8er's Avatar
gap the plugs at 60 maybe.
doubride12
Jul 31, 2015 06:30 AM
NorthernCrew454
Sep 26, 2011 10:55 PM
bjames5
Oct 29, 2008 06:15 AM
shnormo
Nov 8, 2006 12:33 PM
