Aluminum block strength?
Old Dec 9, 2013 | 02:30 PM
Dcapper81's Avatar
Default Aluminum block strength?
hello. recently ive been interested in switching over to an aluminum block and have done a fair amount of research. My only concern is that due to the softer metal, the main caps have a greater chance of ripping out. Are the mains on an aluminum block as strong as iron?
Old Dec 9, 2013 | 09:31 PM
djs383's Avatar
My guess is you'll be fine. It's an engine block not armor
Old Dec 10, 2013 | 09:36 PM
It all depends on how the aluminum block was engineered. Look at the specs and see how much power the block was rated for, and what RPM it can support. If both blocks are built exactly the same, then the iron block will be stronger. At very high power levels other things besides the main bearing caps come into play, including the block actually splitting in half.
Shalamara
Dec 31, 2014 03:18 PM
greenmachine96
Mar 10, 2011 07:05 PM
carguylt1
Feb 18, 2011 11:54 PM
70_boosted
Jun 12, 2007 12:28 AM
