alt problems?
Old Sep 21, 2006 | 11:59 PM
1bad88's Avatar
Default alt problems?
ok so i only run one belt on my 355 it runs the alt,wp/fan,crank.just a vbelt..i keep spinning my belts..when u look at the alt it looks like its a little off it sets bak towards the engine a little bit..the engine is out of a 1970 camaro..i did buy a whole new alt bracket for it and the original one and the new one both did the same thing..is there 2 diffrent brackets for the sbc engines or somthing wat am i doing wrong here?
Old Sep 22, 2006 | 02:36 AM
1969 SS's Avatar
Default RE: alt problems?
try using spacers to even them all up. you can also look at a couple of recent threads on this same subject for ideas instead of having to repeat
Old Sep 22, 2006 | 12:05 PM
Blade's Avatar
June 2007 ROTM
what about buying alonger backet?
Old Sep 22, 2006 | 04:56 PM
If you can't get the pulleys lined up, try going to a fatter belt and deeper pulleys.
mp734
Nov 6, 2013 11:54 AM
nmallory56
Jul 21, 2009 03:34 PM
IZZY1967RS
Jun 19, 2008 10:29 PM
jdubs1813
Nov 12, 2007 04:16 PM
Nov 11, 2007 11:56 AM
