700r4
For your shift problem, first make sure your TV cable is operating properly. Otherwise, your governor could be goofed up.
http://transmissioncenter.net/subject.htm
http://www.transmissioncenter.net/700r4.htm
Converter lockup (if you want it to) can be done with a manual switch, or with an aftermarket lockup kit. summitracing.com carries it.
