5.3L question.
Old Jan 21, 2011 | 12:04 PM
aldie's Avatar
Exclamation 5.3L question.
I have the opportunity to swap a 5.3L 327 LS1 into my Camaro. I cant seem to find much on these engines though. Anyone give me more info about it?
Old Jan 21, 2011 | 03:04 PM
Saint Ebony's Avatar
Third Generation Moderator
March 2010 ROTM
An LS1 is a 5.7L engine. Is it possible you're talking about the 5.3L LS4?
Also, can you give us some info about your car? What year, what engine it had originally, etc?
Old Jan 21, 2011 | 03:06 PM
That is the truck version of the LS1. There is also a front drive version of the same displacement which is not suitable for use in a rear drive car.
Old Jan 22, 2011 | 09:58 AM
aldie's Avatar
I know its a truck engine, and I know for a fact it can work with a rear wheel drive car because it was in a S10. He raced it. Im just wanting to know things like the weight, torque, and HP and other small bits of info on it. I just cant find it.
Old Jan 22, 2011 | 10:12 AM
March 2010 ROTM
Old Jan 22, 2011 | 11:59 AM
Buffalo02Z28's Avatar
An LS1 to 5.3 liter LM7 is a direct swap. Its been done before. Is this a LS1 Camaro that you have? I would rather you perform a swap using the 6.0 liter LQ9 truck motor if you're going to go through the trouble of swapping for a LM7.
Old Jan 22, 2011 | 03:42 PM
aldie's Avatar
Thanks Saint. And Buffalo, im not swapping it myself because I dont know how to do very much to cars let alone swap an engine.
Old May 20, 2011 | 11:49 AM
need4speed069's Avatar
When I do engine swapping to a 5.3 I use the L-33 its all aluminum and the hp and torque are very close to the Ls1's
JPrice
May 20, 2012 03:48 PM
endo
Sep 30, 2010 12:51 AM
josh75camaro
Jan 7, 2010 09:09 PM
