383 stroker spark plug recommendation
Old Aug 27, 2010 | 07:48 PM
microkid's Avatar
March 2011 ROTM
Technical User
Default 383 stroker spark plug recommendation
i need to know what plugs and heat range i should use for this engine. im thinking something colder than stock because of the high compression? http://www.blueprintengines.com/popu...specs&pc_id=98
Old Aug 27, 2010 | 09:38 PM
Since 383 is not a stock displacement, you really don't have a stock plug to start with. If the 383 engine comes with spark plugs, use the ones the builder provided. If it comes without plugs, call the builder & see what they recommend. All things being equal, higher compression should work better with colder plugs, but if you go too cold the plugs will foul. Also, a lot depends on combustion chamber design, camshaft, and how you are going to use the engine.
Old Aug 27, 2010 | 09:45 PM
microkid's Avatar
March 2011 ROTM
Technical User
its going to be mostly street, some strip/fast street. the cam is fairly mild, under .500" lift (the specs are in the link). i was going to order stuff tonight, but i have to wait anyways now for my summit card. ill give blueprint engines a call monday to find out what they recommend
Old Aug 27, 2010 | 10:38 PM
Calling the builder would be the best bet. Also find out what carb, intake, initial, and total spark lead they used. Get some Comp Cams break in oil, flat lifters need special care in breaking in. Also with flat lifters is a good idea to use engine oil high in ZDDP (Zink, Phosphorus), also available from Comp Cams (Muscle car engine oil).
Old Aug 28, 2010 | 02:28 PM
microkid's Avatar
March 2011 ROTM
Technical User
i know all that. they pre break in the engine, which is what allows them to have a 3 year/36,000 mile warrenty. i was thinking of using mobil delvac as that has all the zinc and other additives the old engines need. im running efi, so it may be a different plug requirment than what they used
Old Aug 31, 2010 | 08:03 PM
microkid's Avatar
March 2011 ROTM
Technical User
i talked to blueprint, they recommended that i use ngk plugs and gave me the part number for them. im glad they recommend to me what i recommend to everyone else
Sniper
Aug 22, 2011 03:52 PM
sebi1990
Oct 10, 2010 10:24 PM
Skippysnax
Aug 20, 2008 08:17 AM
vincent77
Jun 24, 2006 10:43 PM
