350 build with nitrous
Old May 27, 2008 | 08:33 PM
Luv2exl8t's Avatar
Default 350 build with nitrous
i have a 350 engine i am planning on building it up and puting aluminum heads on it and running nitrous. I am just trying to get some input on what you guys think i should put in for internals and what compression ratio i should be running. Thanks guys oh yeas the engine is carborated also
Old Jun 1, 2008 | 11:13 PM
31Bravo's Avatar
Default RE: 350 build with nitrous
you don't need aluminum heads find some good 39470403947041, 3947041x or 3927186. for your CR 10:1 is good. I suggest buying the book "how to build max performance chevy small blocks" by David Vizard should be able to find it at auto zone, Checker or another auto parts store.
Hambone
General Racing/Tech
May 25, 2010 08:52 AM
sd9010
82-92 V8 Tech
Jun 28, 2008 10:26 AM
bluovlh8er
Jan 31, 2008 08:13 PM
traXion
Jun 16, 2007 11:38 PM
94Z28interceptor
Oct 25, 2006 02:20 AM
