3400 swap
Old Aug 23, 2007 | 09:39 PM
funnyha_ha's Avatar
Default 3400 swap
I have a 94 3.4L camaro i was wondering what parts will i need to do the 3400 swap.I know i need them off a 99 pontiac grand am GT but what all will i need
Old Aug 26, 2007 | 10:28 AM
blackz87's Avatar
Default RE: 3400 swap
What is the reason for asking about 3.4 to 3400 engine swap?? They are the same engine except for minor differences. GM has been using that engine for 20 + years and there is no advantage to it.[sm=chairshot.gif]
Old Aug 26, 2007 | 11:32 AM
The 3400 has much better heads with canted valves, better manifold,uses roller lifters and roller rockersallowing the use of amore aggressive camshaft. The 3.4 used in the Camaro has a goofy oiling systemwhich does not allow theuse roller lifters, but can take the 3400 heads and intake. The 3400 block does not fit in the Camaro because it is built for front drive cars.
Old Aug 27, 2007 | 12:39 PM
CamaroKid16's Avatar
Old Aug 27, 2007 | 12:40 PM
Sicilian
Feb 2, 2014 10:18 PM
woodstock
Apr 27, 2012 11:02 PM
Saskatoon94
Nov 10, 2011 09:33 PM
Dr. Evil
Dec 14, 2009 11:06 AM
94CamaroSFI
Aug 19, 2007 11:20 PM
