305 firing order. i need some help please
Old 11-10-2008, 08:14 PM
kyphur's Avatar
Default RE: 305 firing order. i need some help please
ORIGINAL: Camaro 69
Oh man, I have a feeling you're going to be a second gear member by the time we're done!!!
Ha ha ha, Level up!.
  #52
Old 11-10-2008, 09:18 PM
OK c4camaro, take a look at this video. It will walk you through the ignition timing and plug wire set-up procedure:
Ignition Timing
  #53
Old 11-10-2008, 09:27 PM
kyphur's Avatar
Yeah, Boxwrench has some cool videos. I like the one that they had with the 351 windsor that they pulled from a boat that had the chocolate milkshake in it.
  #54
Old 11-11-2008, 01:01 AM
c4maro's Avatar
ok. that video helped ALOT. thanks alot camaro 69 and zyphur and z28pete. i have a day off school tommor and i for sure get her running. its clear to me now and ive learned alot about this kind of stuff. thanks guys... and be ready for my thread on my hi-performance intake manifold swap lol.
thanks again guys.
sinscerly, Cole Mithrush.
  #55
Old 11-11-2008, 05:17 PM
c4maro's Avatar
ok. I deffinatly have the wires in the right spot. but theres no spark. what do i do know
  #56
Old 11-11-2008, 06:08 PM
kyphur's Avatar
Have you checked your fuses and relays?
  #57
Old 11-11-2008, 06:52 PM
Have you checked for "keyed" power at the distributor, with a test light or meter yet?
Time for using some deductive reasoning. The engine ran before the headers install, but now it doesn't run after the install...
Look at everything that you layed a finger on, every wire, connection, etc. Did a wire to the distributor or coil get knocked off or broken?Maybe the headers shorted on something and popped a fuse, breaker, relay, or fusible link, as mentioned ^ ?
  #58
Old 11-11-2008, 08:00 PM
c4maro's Avatar
i dont think i touched anything, and i have a battery meter testeri think, but it only says 9 volts on it. ill see what i can do about the fuses. i got a haynes manual for 1984-1987 camaros. but my engine block is suposobly 1991 beacuse it has centre bolt valve covers.
  #59
Old 11-12-2008, 05:47 PM
kyphur's Avatar
Centerbolts started in 87 I think but I'm not 100% sure. Maybe even a little earlier. I almost bought some 187 heads centerbolt that were from 87 for 25 bucks that go on a 305.
Where are you getting the 9 volts from? Like, where are you putting the leads from your voltmeter to?
  #60
Old 11-14-2008, 09:57 PM
c4maro's Avatar
after 300 hits and 60 replies, im embarresed to say it was an unpluged dist. cap wire. i pluged the wire in. and my dad tapped the key with my #1 sparkplug out to check for spark after the wire being pluged back in. and unexspectinly it fired right up and sounded AWSOME. thanks alot guys for all the help. this thread has been a benefit to me now that all u guys have taught me if i ever run into a problem like that. but in the end... it was an unplugged wire the whole time! thanks guys anyways, dont be mad at me for wasteing ur time beacause you guys really did teach me alot.
Quick Reply: 305 firing order. i need some help please
