3.4l camaro headgasket replacment HELP!!!!!!!
Old Aug 9, 2009 | 10:30 AM
bxdragon's Avatar
Default 3.4l camaro headgasket replacment HELP!!!!!!!
ok as the title says in need help with my head gasket replacement i am trying to remove the upper intake manifold but i strip a bolt on the fuel pipe hold down plate wanted to know if i could remove the upper intake manifold with out moving the fuel rail . it a tight space and i can get grip on that bolt please help
__________________
Old Aug 9, 2009 | 10:48 AM
bxdragon's Avatar
bump some on please check this out
94ChevyCamaroV6
Oct 2, 2012 08:45 AM
Dan Cox
Dec 21, 2011 07:45 PM
RFxCamaro
Sep 23, 2010 10:18 PM
TURBO TEG
82-92 V8 Tech
Apr 27, 2007 05:18 PM
Chappie99
Apr 11, 2007 02:59 AM
