2000 3.4 Venture connecting rod question
Old Nov 2, 2007 | 11:32 AM
lennyob's Avatar
Default 2000 3.4 Venture connecting rod question
I'm overhauling a 3.4 in a 2000Chevy Venture (sorry...not a Camaro!). I think it's the "E" engine.Is replacing rod bolts during tear-downrecommended on this engine? The reason I ask is that the torque spec is "18 ft/lbs, then anadditional 100 degrees", similar to the way torquing the stretch-to-yield head boltsis described.
Thanks
Old Nov 2, 2007 | 02:00 PM
Default RE: 2000 3.4 connecting rod question
It is always a good idea to replace the rod bolts, but mandatory in stretch to yeild bolts.
Old Nov 2, 2007 | 02:53 PM
lennyob's Avatar
I appreciate the input, but that much I know. The problem is neither the dealership, or GM's tech help line could tell me whether these are stretch to yield bolts. The only clue was that the dealership doesn't keep them in stock. So, since I'm sure they work on these engines with depressing frequency, they may notneed replacement. Otherwise, the dealer would keep them in stock. Any dealership line mechanics out there?
Thanks
98v6ttop
Oct 14, 2013 07:31 PM
emptysmile005
Feb 23, 2011 04:33 PM
sewerrat
Aug 6, 2008 02:41 AM
