Detailing Discuss detailing your ride within.
removing a badge
Old 05-27-2007 | 10:40 AM
dragonoz's Avatar
Default RE: removing a badge
Hair dryer and dental floss to take it off and Goo Gone for the excess glue, worked on my motorcycle!
Old 07-20-2007 | 02:29 PM
InfraredMonkey's Avatar
Actually, I would be proof of the dental floss. After reading a couple posts and I decided to try it myself. I have a dealership badge on there, which is annoying by the way.
I took normal floss and dug into the tape. All I did was take about arm length of string and pretended I was floossing my teeth, but instead the backing of the badge. It took a couple strings, but about 5 minutes later it came off. I had some excess tape, but I peel with my thumbnail, then cleaned the surface with a touch of PineSol.
Badda-bing Badda-boom, no more dealership badge. (For Ref: It was about 82 degrees outside and I used cheapo floss).
I hope this helps!
Old 07-24-2007 | 12:40 AM
01camaro.dude09's Avatar
alright thanks for all the help. i removed my factory black RS emblems and put my new silver ones on. ill post pics once i take some
Old 09-05-2007 | 09:52 PM
84 z .....'s Avatar
heat guns for old household oil paint works if u arent in a rush. Gas works to but not so well for me
[align=left] [/align]
Old 11-02-2007 | 01:06 PM
1969 SS's Avatar
ORIGINAL: 84 z .....
[align=left][/align]
you should never use a heat gun...especially if you are in a rush!!
if you aren't experienced with a heat gun, it is extremely easy to hold it up too long and just when you think it's still good, you will take the gun away and about 20 seconds later the paint will start to bubble
Cherryred
04-19-2015 04:46 AM
'94Scrat
06-12-2011 11:42 PM
DarlingReject
04-03-2010 05:52 PM
Labyrinth9
03-20-2008 04:51 PM
Spartan66
03-11-2008 02:59 AM
Quick Reply: removing a badge
