Detailing Discuss detailing your ride within.
leaf springs + Por15???
Old Dec 10, 2008 | 10:04 AM
78LT350's Avatar
Default leaf springs + Por15???
I was thinking about using Por15 on my rear end soon to make it look a little nicer back there, but can I use it on my leaf springs?? I've noticed some rusting when I took a look at them (They're fairly new springs). You think it's a good idea to use it on my springs? If not, anything I can use to stop the rust? Thanks a bunch!
Old Dec 11, 2008 | 05:27 AM
blackz87's Avatar
Default RE: leaf springs + Por15???
Why the question?? Por 15 will work on anything except for high heat areas.
Old Dec 11, 2008 | 08:28 PM
brnyrdanimal's Avatar
it will work great, but I want to know where to find replacement pads for between the leaves, the little square clip on plastic ones, cause mine are worn out and I can't get them out without breaking the clips.
Old Dec 12, 2008 | 12:04 AM
78LT350's Avatar
Ok, nevermind...I found more info at por15.com. It says it can be used on suspension, yay! And brnyrd, to answer your question...I only found one place that has what you are looking for and it's at www.npdlink.com. However, its only for 68 and 69 comaro. Take a look at it, maybe it'll work because it's for 4-leaf or 5-leaf. Hope that helped
nasty50
67-69 V8 Tech
Oct 20, 2011 06:18 PM
camarosrnice
May 14, 2009 09:11 PM
jenz
67-69 V8 Tech
Sep 30, 2008 01:30 PM
danny67
Nov 11, 2006 09:37 PM
