leaf springs + Por15???
I was thinking about using Por15 on my rear end soon to make it look a little nicer back there, but can I use it on my leaf springs?? I've noticed some rusting when I took a look at them (They're fairly new springs). You think it's a good idea to use it on my springs? If not, anything I can use to stop the rust? Thanks a bunch!
RE: leaf springs + Por15???
Why the question?? Por 15 will work on anything except for high heat areas.
it will work great, but I want to know where to find replacement pads for between the leaves, the little square clip on plastic ones, cause mine are worn out and I can't get them out without breaking the clips.
Ok, nevermind...I found more info at por15.com. It says it can be used on suspension, yay! :) And brnyrd, to answer your question...I only found one place that has what you are looking for and it's at www.npdlink.com. However, its only for 68 and 69 comaro. Take a look at it, maybe it'll work because it's for 4-leaf or 5-leaf. Hope that helped
