Computer & Fuel Systems Talk about the control module, fuel systems and delivery, customization and more.
Starting Trouble
Old Dec 31, 2010 | 04:25 PM
Brandon1992's Avatar
Exclamation Starting Trouble
Hello EveryOne i have a 94 camaro v6 3.4L i just recently got it a few days ago and it will not start i dont know why i've checked a lot of things like the sparkplugs and all that ... if anyone had any ideas on what it can be let me know please.
Old Dec 31, 2010 | 04:57 PM
BasicConcepts's Avatar
Technical User
are you getting fuel is the pump priming when you first turn the key in the middle of the upper intake there is a plastic cap next to the FPR take the cap off there should be a valve stem looking thing push in on valve and see if fuel comes out
Old Dec 31, 2010 | 05:12 PM
ok and if it is getting fuel that way then thats not the problem and what could it be if theres no fuel going to it
Old Dec 31, 2010 | 05:15 PM
Technical User
if theres no fuel there next you need to check the pump there is a purple wire on the pass side of the car near the strut tower its the pump test wire supply 12 volts if the pump turns on theres a problem in the lines (usually the filter) if it doesnt come on the pump will need to be replaced
Old Jan 4, 2011 | 12:19 PM
Question
The Fuel Pump Turns on Could It Be A Bad Pump Or Something Cause i Checked All The Lines And They All Get Fuel But The One That Connects To The Fuel Filter... ive looked Online And It Looks Like A Bad Pump That It Will Turn On But Not Pump Or Something Like That
Old Jan 4, 2011 | 02:41 PM
Technical User
could be a clogged filter before you go sinking money into her just guessing get the fuel pressure tested you can rent the gauge from autozone its like 100$ but you get that all back when you return it
Old Jan 4, 2011 | 11:30 PM
you think its a clogged filter do you think it could be a line because the only line im not getting fuel or very minimal fuel out of is the rubber one that goes from the pump to the filter its some rubber/plastic hose that clips in and i dont know if it is putting enough pressure through that line to the filter and then after the filter i dont know if its clogged either and in the tank should the rubber hose be on the smaller fitting on the left or the longer one that connects to the pump then out the one to the filter or is that the return?
Old Jan 5, 2011 | 12:58 AM
Technical User
do you have access to an air compressor if so take off the filter and disconnect the lines that go to the rail and slowly pump air thru the lines at the filter (drop the compressor to 50 psi just over operating pressure you dont want to blow a line if that seems to not work boost it up a little but not to much also have some hold a clear jar on the lines that go to the rail so you can see if it is clogged) it sounds like you have the pump out too you can do the same with the lines there this will clear out the lines pretty good as for the rubber lines take some pics and point out exactly what your talking about using MS paint (red circles and arrows) that way i know exactly what your talking about
also pull the filter and shake into clear glass jar and report whats inside
im trying to avoid the pump because its like 150$ and a filter would only cost like 10$
Old Jan 5, 2011 | 01:52 PM
Exclamation
Do yOu think it could be the fuel regulator thats not pushing enough psi
Old Jan 5, 2011 | 02:37 PM
Technical User
if you say you getting low press at the filter than no the reg is on the rail
