Computer & Fuel Systems Talk about the control module, fuel systems and delivery, customization and more.
Start , No start
Old Apr 6, 2021 | 10:21 AM
rj100n2's Avatar
Default Start , No start
My 1997 Camaro convertible has a starting problem. Sometimes it will start ,sometimes it wont. Never know when it will happen. Battery and starter are fine. Someone told me it could be in factory security system. Any ideas ? I'm afraid to shut it off if it does start. Can't leave it running all of the time Please help.
Old Apr 7, 2021 | 06:01 AM
Everett#2390's Avatar
1. No start - engine cranks over, but no run?
2. No start - engine does not crank over by starter motor?
If #2, VATS socket in column may not be reading the key chip. check reading of chip at column connector by disconnecting and measure ohms of the two thin white wires going up into column.
No read, bad socket. Steering wheel needs removed and socket replaced. They can be gotten from a GM dealer.
Old Apr 10, 2021 | 07:36 PM
Could also be your fuel pump is on it's way out, not uncommon at all. Next time this happens, give it a shot of starting fluid into the throttle body. If she fires right up, you have a fuel supply problem.
Old Apr 14, 2021 | 08:01 PM
rj100n2's Avatar
Doesn't even turn over
Old Apr 15, 2021 | 05:54 AM
If VATS doesn't read the key chip, no crank.
Old Apr 21, 2021 | 08:59 PM
rj100n2's Avatar
thanks
Double
Oct 12, 2019 06:44 PM
camarog2
Jan 20, 2010 07:36 PM
BrandNew
Aug 1, 2008 08:15 PM
new2it
Aug 22, 2007 01:31 PM
mitymouse
Mar 27, 2006 12:25 AM
