Holley Transmission Kickdown Linkage Adapters
I picked up a new Holley Street Avenger carb to try out and had to purhcse the Holley 20-35 lever extension and 20-40 kickdown stud. No pictures or directions. Anybody have a picture of these correctly installed on the carb? Thanks!
Check out page 5 of the manual that came with your carb. If you got your carb second hand without a manual then check it out here. Hope that helps!
