Computer & Fuel Systems Talk about the control module, fuel systems and delivery, customization and more.
Fuel system problem
Old Oct 24, 2009 | 01:36 PM
1979_Macho_Z-004's Avatar
Default Fuel system problem
I have 1979 z28. Not sure how long it was sitting before I bought it. But it drove fine for the first 4 months. Then It started have a hesitation and then would eventually die. I thought it was a vapor lock issue since it was in mid-summer. I changed out and insulated the fuel line from the fuel pump to the carb. This seemed to help for a few weeks. Then it got worse. It wasn't getting any fuel to the carb, so I replaced the fuel pump. And that fixed it for two days. Then I thought it might be a carb problem, thinking the float was getting stuck, so I re-built the carb. It didn't fix it. I am starting to wonder about the gas tank itself. Is there a way to find out if the tank has something in it that plugs the pump? I have this problem with a full tank or not. The books I have don't show a diagram on how the gas is drawn out of the tank.
Old Oct 31, 2009 | 10:00 AM
crug75hid's Avatar
First you check the fuel tank's cap some times it may cause vapour lock also, if it is ok, then there should be a hairy crack or leakage in the fuel pipe line. There may also a problem in fuel filter chock up. So go threw all these once.
Old Oct 31, 2009 | 10:54 AM
if its carb then there should be a screen were the fuel line goes into the carb. check it. u could have a pluged fuel pickup in the tank or the float in the carb could be sticking. how old is the carb.
Old Nov 29, 2009 | 12:42 AM
nelson.jones07's Avatar
Better you find this answer from the service provider or on several related websites.
Old Dec 18, 2009 | 02:46 AM
archebald23's Avatar
i had a similar problem before and i found out that i had a faulty fuel tank cap causing vapor lock and fuel spillage.. If its still not the problem, i advice you to let your mechanic check, it could be a lot of things.
paris0145
Feb 28, 2015 01:53 PM
rickeydg
Dec 4, 2012 02:22 PM
filipski
Jul 27, 2011 12:24 PM
roman36
2010+ V6 Tech
Jul 22, 2011 03:50 PM
xhardkn0ckz
May 1, 2007 11:42 AM
