cleaning gum varnish in gas tank
I'm working on a 88 camaro v6 MPFI with severe varnish in the tank. The car has sat for 3 years and does not run. The previous owner replace the pump once before which failed shortly. I need your input to clean out this severe amount of hard gum and varnish formed in the tank and fuel inlet lines. I'm trying to prevent buying a new tank. If anyone has had this problem, what did you use to clean it? I'm trying to avoid buying a new tank, sending unit cradle and fuel lines. I am replacing the fuel pump again though. I've gotten suggestions from local mechanics like soaking everything with diesel with glass marbles and shaking the heck out of it, to pressure washing. Please give your input. Thanks
RE: cleaning gum varnish in gas tank
i'm with pete. buy a new tank. if a new tank weren't available, then i'd consider chemically cleaning and sealing the existing tank.
at advance auto, they're $200 without the filler neck, and $230 with the filler neck. with a car this old, i think i'd opt for the one with the filler neck.
Yep, you guys were right. The tank just kept on rusting on the inside.Back in Nov. 06 I finally broke down and bought a new tankalong withanother fuel pump and strainer. Since then I haven'thad a problem. Thanks again.
