Computer & Fuel Systems Talk about the control module, fuel systems and delivery, customization and more.
BLM and O2 problems
Old Mar 18, 2010 | 08:28 PM
JordanT's Avatar
Default BLM and O2 problems
For some reason my BLM sensors and my O2 sensors are reading the exact same numbers all the way through. BLM is staying at 128, perfect, but still should be changing. Any input would be much appreciated.
Old Mar 19, 2010 | 08:57 PM
There are no BLM sensors. The BLM (Bloc Learn, a variable table) depends on the O2 sensor output. Since the O2 sensor appears to be stuck, the BLM will not change. Also if the PCM does not see an O2 sensor signal, or is temporarily disconnected, the BLM will default to midrange in order to keep the engine running.
Old Mar 20, 2010 | 04:36 PM
JordanT's Avatar
Oh right. I did not mean to put BLM sensor. But my readings are all off. I am thinking since I am getting an error code 43 it could be that the knock module is not working and I will replace it with an LT4 module.
mp734
Nov 6, 2013 11:54 AM
nmallory56
Jul 21, 2009 03:34 PM
IZZY1967RS
Jun 19, 2008 10:29 PM
jdubs1813
Nov 12, 2007 04:16 PM
Nov 11, 2007 11:56 AM
