Computer & Fuel Systems Talk about the control module, fuel systems and delivery, customization and more.
94 z28, need to know values for live scan, as far as what numbers
Old Dec 18, 2010 | 03:26 AM
hoursetraitor's Avatar
Default 94 z28, need to know values for live scan, as far as what numbers
i just got my usb aldl cable and im using tts datamaster. but i dont know what the numbers should be for say my maf, map, and feul trim. i searched around and just found confusing stuff. will alldata tell me numbers? thanks in advance
Old Dec 18, 2010 | 11:57 AM
This is from the FSM for 94 Z28
Attached Thumbnails 94 z28, need to know values for live scan, as far as what numbers-t1-10001.jpg
Old Dec 18, 2010 | 02:09 PM
right on almost everything i need .
but i have no idea what kinda number i should be reading for the mass airflow in grams per sec. it give no idea on that sheet.
i think i was getting around 6.5 grams per sec at idle.
basicallly iheres my numbers at an idle, keep in mind im getting about 10mpg.
rpms 575
map hg 13.9
fuel trim 16
l term counts 145 140
s term counts 125 128
inj base pulse width (bpw)l/r=4.21 4.17
inj duty cycle percent 2.0 2.0
o2 mv 813 413
tps volts .69
spark advance 19.0
spark retard 0.0
knock count 1482
egr dc 0.0.
ccp dc 0.0
iat 97.7 f
a/c evap temp 63.0 f
a/c press hi side 65.7 psi
idle rpm 550
iac pos 14
im not sure why my idle seems to be set at 550 but it is. freescan shows that as well as tts datamaster.
i cant get any other software to work, i have no codes, but i think its efi live show dtc for the trans but they say mil fault after them.
craby
Mar 10, 2012 08:32 AM
Carichey
May 11, 2011 06:05 PM
7d9_z28
Dec 26, 2007 09:19 PM
55chevyguy
Apr 4, 2007 07:22 PM
jrwatty
Jun 19, 2005 07:25 AM
