Computer & Fuel Systems Talk about the control module, fuel systems and delivery, customization and more.
91 RS speedometer not working
Old Jun 28, 2020 | 10:11 AM
jmschilling's Avatar
Default 91 RS speedometer not working
I am having a problem with my speedometer in a 91 RS, 305, carb and T5. I have tried the drill a hole and use long piece of wire to reset speedo back to zero, worked for a short time now problem is back. I have removed all the junk on passenger firewall, ac, heat etc. basically stripped out all computer junk. Ignition is toggle switch and relay as well as fan, fuel pump and starter. I have repair guide from austins in pdf form, however, does not go into any wiring detail or schematics. Any help would be appreciated.
Old Jun 30, 2020 | 01:56 PM
Everett#2390's Avatar
The speedo gear, now an AC generator, is wired into the PCM, then PCM to speedo. for indication.
Old Jun 30, 2020 | 02:19 PM
Default speedo not working
what gear are you talking about? no speedo gear on 91 t5 transmission
Old Jun 30, 2020 | 06:38 PM
Get a Haynes manual. Thereis a toothed wheel with a coil;picking up the pulses and inputs to PCM.
CameroLBC
Dec 7, 2025 10:43 AM
Jon Englert
Jun 21, 2020 10:44 PM
eglide0251
82-92 V8 Tech
Oct 8, 2013 08:22 PM
crapsman
82-92 V6 Tech
Aug 2, 2012 01:41 AM
91ConvertibleCamaro
Jan 1, 2006 03:24 PM
