Computer & Fuel Systems Talk about the control module, fuel systems and delivery, customization and more.
4L60E use into a non-ECM vehicle
Old Dec 19, 2006 | 12:01 AM
sewerrat's Avatar
Default 4L60E use into a non-ECM vehicle
I recently removed a good running 4L60E and was intrested in using it in a older non-computer controlled vehicle. I know that the easiest way is to purchase a trans controller but I was wondering if I could hook up the original ECM for the 4L60Ebutnot theEFI side? Would the ECM still need fuel and ignition signals to run the trans? The reason I ask is that the controller isn't cheap and my current Carburetor and HEI distributor is fairly new but I still wanted the benefit ofhaving an overdrive trans. I'm sure using a 700R would be even easier butthe 4Lis on hand, free and is known to be good. Thanks for any replies.
Old Dec 19, 2006 | 07:16 PM
Default RE: 4L60E use into a non-ECM vehicle
The PCM that comes with the 4L60e looks at various engine sensors to determine when and how the gears are shifted. Even if your engine has all those sensors the PCM will have to be reprogrammed to work properly. You will be much better off with the user programmable stand alone controller, and cheaper in the long run.
Old Dec 28, 2006 | 02:18 AM
sewerrat's Avatar
Pete if i did go back and aquired the original engine that mated to this a/trans and got the complete harness, what would I need to make the trans run a cable operated speedo? Do I use a drive gear and ext. tail housing from a 700R4?
Mike
Old Dec 28, 2006 | 01:26 PM
The electronic transmissionhas a VSS (vehicle speed sensor) mounted in the same place where the spedometer drive goes. The PCM or cotroller need the input from the VSS in order to know when to shift gears, which leaves you without a spedometer drive.
Old Jan 1, 2007 | 02:34 PM
JD1969's Avatar
You could use a full manual VB in the 4L, but it won't shift by itself anymore.
Jim-Bob
Apr 7, 2013 02:46 PM
jrgearhead
Dec 28, 2011 12:41 PM
rostie
Dec 31, 2010 02:09 AM
