Stereo color code with bose?
Old Sep 21, 2009 | 11:38 AM
typappy's Avatar
Default Stereo color code with bose?
Help! My son has a 96 Camaro RS the previous owner or someone took out the Bose head unit but cut the wires instead of just unplugging them. My question is in each of the two speaker wire bundles there are four wires three colored and one bare where should each wire hook up. I did get a Scosche output converter but it's still all confusing.
Old Oct 1, 2009 | 09:49 PM
greenarrow's Avatar
September 2009 ROTM
The search feature is a awesome tool!
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6 1/2″
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6 1/2″
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire (+): Yellow
Left Rear Speaker Negative Wire (-): Brown
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Old Apr 25, 2019 | 09:26 PM
Shawnk111's Avatar
I've been trying to find a diagram for how I can wire my Bose to an aftermarket stereo. I don't believe these color codes are accurate for the Bose system. There are no speaker wires. I've done some research on it and you have signal wires that go to the amp.
If anyone knows how to wire the Bose system to an aftermarket head unit I'd be grateful. Whoever had the car before me chopped off the harness so I don't have anything to work with.
ztwentyate
Apr 30, 2015 06:25 AM
Mikeroc283
Apr 14, 2014 07:39 AM
husker_camaro95
Aug 9, 2010 09:12 PM
95chevyman
Nov 10, 2009 01:22 PM
remlle
Sep 28, 2009 07:53 PM
