Roadmaster sub tube install
Old Apr 26, 2012 | 10:53 PM
MKCoconuts's Avatar
Okay, depending on your RPO codes, 97 should have two door speakers and two more where the rear seats are at. Those four should just be normal speakers and may/may not have their own personal amps, you'd have to pull one out and double check. Then there should be two more in the hatch that are subs and for sure have their own personal amps.
I don't remember what year they switched it, but for instance, my 93 Z had the option of 5 speakers or 3, in my case, only 3. Two in the doors and one sub in the back on the drivers side. Where else the 5 speaker option had all that, plus two near the rear seats.
As mentioned before, you need a RCA converter thingamajig. Walmart sells them, as do most audio stores. There is, however an alternative. You can buy an aftermarket head unit, either toss all the old speakers and splice in aftermarket ones (option A) or still buy the aftermarket head unit and ditch the amps and solder the speaker wire straight to the original speakers (option B). I meant to do a write up on how I did it (option A), but never found the time.
It sounds more complicated than it actually is.
Old Apr 27, 2012 | 06:14 AM
H2C's Avatar
H2C
Close, but I have four speakers, two in the front and 2 in the hatch. Along with 2 subs near the rear seat.
Old Apr 28, 2012 | 11:19 AM
MKCoconuts's Avatar
Subs should be in the hatch not near the rear seats. Rear seats should be just regular speakers.
Old Apr 30, 2012 | 06:44 AM
H2C's Avatar
H2C
Thats backwards from my car. I dont know why but my subs are in the rear seat and the hatch is regular speakers
Old May 1, 2012 | 10:47 AM
MKCoconuts's Avatar
Huh. I suppose may be GM switched it when they added the passenger side hatch to the mix. You'd have to talk to someone with the same year and RPO codes and see if theirs is the same. I just don't see any sense in putting subs next to a passengers ear.
Old May 1, 2012 | 01:54 PM
H2C's Avatar
H2C
I just went ahead and sold the stuff off lol. Im a little impatient
Old May 2, 2012 | 07:43 AM
MKCoconuts's Avatar
That works too. In my opinion, it's better with the aftermarket stuff any ways.
Old May 2, 2012 | 12:27 PM
H2C's Avatar
H2C
Well i got to thinking and realized i really wanted an interior like this anyway so why put that in now just to take it out later
Old May 2, 2012 | 01:02 PM
MKCoconuts's Avatar
The steering wheels on the wrong side.
Old May 2, 2012 | 02:54 PM
  #20
H2C's Avatar
H2C
Like i said, Just like that
Vistagecko
Jun 7, 2011 09:37 AM
boostedzx3
LS Series Tech
Jul 22, 2010 09:16 PM
jbe123
70-81 V8 Tech
May 24, 2010 11:21 PM
rsh3429
Apr 4, 2009 11:12 PM
gotalcoholmanup
Apr 11, 2006 09:24 AM
